How To Repair a Padded Dashboard
When restoring older cars, it is often too expensive to replace a cracked dashboard. And, that is assuming a new dash board is available. In cases where new parts are too expensive, too difficult to find, or, impossible to find, you will need to restore what is already there. The padded dashboard on this 1971 Oldsmobile Vista Cruiser is a good example.
Step 1: As you can see, this dashboard has a hole that needs to be repaired. Most old cars and some new cars have dashboards made from vinyl over urethane foam. Over time in the sun, the vinyl gets brittle and the dash board gets cracks. Many newer dashboard don't have any foam at all. Instead, they are made from injection molded TPO or ABS. But, these dashboards can also get cracked or get holes from exposure to the sun.
Step 2: Use 80 grit or 180 grit sandpaper to bevel into the damage. Make sure that you sand out any dried-out and crusty foam, too.
Step 3: Use Plastic Welder to melt some of the polyurethane welding rod into the void that was created when you sanded out the crusty, dried out foam. The urethane rod is very flexible and closely simulates the urethane foam. Turn the temperature all of the way up and the melted rod come out bubbly. Some of the bubbles remain encapsulated within the polyurethane and simulates the foam even more. Overfill the hole slighly. You will be sanding it down and it is better to overfill slightly than having to find out that you need to melt more polyurethane rod into the hole after you have sanded it.
Step 4: This is what it looks like after filling the hole.
Step 5: Use 80 grit sandpaper to sand the urethane level with the surrounding area. The urethane is very stretchy and elastic so, if you use really short strokes when you sand, it may just stretch back and forth rather than getting ground away. A good way to prevent the back-and-forth stretching is to put your thumb on top of the sandpaper over the area that you need to sand. Then, pull the sandpaper while maintaining downward pressure with your thumb over the urethane.
Step 6: This is what the damaged area looks like after the urethane welding rod was sanded down.
(to be continued)
Edited by Frost Auto, 06 August 2015 - 01:19 PM.
