Wosp 1.0Kw Gear Reduction Starter Re-Configuration
7 replies to this topic
#1 minimole23
minimole23
  • 32 posts
Posted 07 August 2015 - 09:05 PM
Since buying an LMS011 inertia type starter motor with the intention of using an SH engineering featherweight flywheel, they have changed their ring gear to pre engaged type.
Does anyone have a pre-engaged/aftermarket ring gear type starter handy they could check the tooth count on the pinion for, as I would like to change the pinion to suit the revised ring gear.
Also a side on shot too to make sure the mounting plate is the same would be beneficial
James
Edited by minimole23, 07 August 2015 - 09:06 PM.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 August 2015 - 09:59 PM
I have used a couple of these before and they are 11 teeth pinion for the pre-engaged ring gear with 129 teeth http://www.autoelect...40/category/241
#3 Richie83
Richie83
  • 1,495 posts
Posted 08 August 2015 - 09:03 AM
I have the LMS010 if that helps at all?
#4 minimole23
minimole23
  • 32 posts
Posted 08 August 2015 - 11:55 AM
Rich, that is the pre-engaged type you have. Please could you double check the pinion is 11 teeth, if possible even a measurement at full extension of the pinion to the starter body too.
Those powerlite ones look similar to the wosp ones.
James
#5 Richie83
Richie83
  • 1,495 posts
Posted 08 August 2015 - 12:18 PM
It's 30 mm full extension and it has 9 pins.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 09 August 2015 - 05:50 PM
? 9 tooth is normally for the inertial ring gear of 107 teeth
#7 Richie83
Richie83
  • 1,495 posts
Posted 09 August 2015 - 06:20 PM
that's right. My bad 😌
#8 minimole23
minimole23
  • 32 posts
Posted 10 August 2015 - 06:41 PM
Measuring things, for some reason despite having an ultralight pre-verto flywheel the inertia type starter doesn't seem to engage fully, only about 7mm. so clearly require one for the appropriate ring gear location.
Time to flog it and buy the correct starter motor, to save the cost of adapting it.
