Edited by minipete, 08 August 2015 - 09:17 PM.
Seam Sealer.
Posted 08 August 2015 - 09:17 PM
Posted 10 August 2015 - 08:55 PM
Posted 11 August 2015 - 02:56 PM
Posted 11 August 2015 - 04:53 PM
Posted 11 August 2015 - 06:34 PM
Posted 11 August 2015 - 07:34 PM
Posted 11 August 2015 - 08:17 PM
I would just buy some pu sealant in a tube and put it on with a mastic gun then smooth over with your finger, panel wipe or water stops it sticking,
I also used panel wipe on my finger to smooth it, ends up with a very neat finish. I wouldn't use water as the moisture would get through the porous primer and start to rust the panel underneath.
Ps
If you apply etch primer on top of the seam sealer it may lift the edges of the seam sealer.
How long are you leaving the etch primer before you apply the sealer?
Posted 11 August 2015 - 10:39 PM
Stick it on a decent thickness, say an inch wide and 1mm or so thick.
Posted 12 August 2015 - 03:59 PM
Posted 12 August 2015 - 07:04 PM
Guys I am not an expert but just some observations and my opinions based on what I have learnt so far:
Etch Primer - Designed to go onto bare metal only, it eats into the metal to provide an effective protective coating, not to be use over anything else just bare metal, so I would not paint any Etch Primer over the Seam Sealer.
Seam Sealer - best applied over a primer, not applied onto bare metal, etch primer or Epoxy Primer would provide a better first layer.
