Hi all. Im here reaching out in despair at my mini. Its originally a mayfair, converted to a convertible and running a 1275 currently.
So i have restored the body but not the engine. All i did was remove the head (changed gaskets) repainted and refitted.
Ive checked static timing (tdc...... rocking on 4, rotor pointing approx 2 o'clock position) and also been over the rockers and adjusted tappets.
On the current system 65dm4 distributor and dlb102 coil. I have a good spark and fuel but no starting...... I get a little back fire from time to time and the carb breather coughs some white/grey smoke but nothing!
In desperation i have removed the full ignition system and carb from my spare mini (next project). Fitted all this and guess what.....Nothing!! same stuff even though the spare mini was driven a week ago so i know its good.
So here i am people, a damsel in distress seeking a gurus help.
By the way, tried clamping off the fuel line and tipping fuel into the carb, same results...nothing.
thanks guys and gals
