Flatting Back Then Clear Coat?
7 replies to this topic
#1 Yams
Yams
  • 644 posts
Posted 09 August 2015 - 08:57 PM
I've been painting some arches up today, I have been using acrylic. I was planning on clear coating them because i wanted a high gloss finish, however i have a paint run on one of them. I was planning on flatting it back slowly by wet sanding it with some 2500 grit wet and dry, then applying the clear. Can i do this? Can i just flat them and polish without applying clear and still get good results? After prep (primers etc) they have had 5 steady coats of topcoat.
Sorry for blurry photo, doesn't focus well on paint.
Many thanks
#2 Coxie
Coxie
  • 461 posts
Posted 09 August 2015 - 10:00 PM
If you want to lacquer them then you can flat the run off first with wet and dry and a block but you will need to key up the whole arch after with either wet and dry or a scotch brite pad to give the lacquer something to key to.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 August 2015 - 10:16 PM
There is no reason why you can't polish up the colour coat if it is just a flat colour.
Although the lacquer will give you a tougher finish
#4 Yams
Yams
  • 644 posts
Posted 10 August 2015 - 12:22 AM
Ok cheers guys. I'm somewhat a novice as you will be able to tell, so i think i'll stick with removing the run and polishing them without lacquering.
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 August 2015 - 09:04 AM
Make sure you flat it wet with 2000
#6 Yams
Yams
  • 644 posts
Posted 10 August 2015 - 09:24 AM
I've only got 2500, will that be ok?
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 August 2015 - 09:27 AM
It will be ok, it will just take longer to flat back is all.
Put a drop of car shampoo into a bucket of warm water and use that for flatting as it will keep friction down and help cut into the paint better.
keep the paper wet all the time and dry the part of regularly to check how far you have gone so that you can stop as soon as you have gone far enough to get a flat even finish
#8 bluedragon
bluedragon
  • 288 posts
Posted 11 August 2015 - 12:04 AM
You'd have to flat the paint anyway to apply a clear coat. The exception is if this were a two-pack type paint that is clear coated within a limited time period (usually ~24 hours) of the color coat being sprayed. (The still curing paint chemically bonds to the clear coat.)
Once the paint has hardened, clear coat won't stick to a glossy, shiny finish. So flatting everything is needed in any event, clear coat or not.
