Spraying U-Pol Gravitex With And Without Celly Thinners (Mix Ratio)
3 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 12 August 2015 - 07:48 PM
Hi;
Does anyone have any tips on spraying U-POL Gravitex? i.e. does it need warming up in hot water first? AKA the tips in this guide albeit for a different type?
I'll be using a Shutz Gun but some areas I will need a smooth finish so I will be spraying it in an LVLP Gravity Gun using Cellulose Thinners - what's the mix ratio? is it 50 / 50 or less?
Also what would be the best needle? I have 1.8 and 1.3?
Thanks in advance
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 12 August 2015 - 07:54 PM
I think it would help warming it up to make it a bit runnier, I think it says on the bottle the ratio and the gun needle for the different finishes .
Edited by alex-95, 12 August 2015 - 07:55 PM.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,091 posts
  • Name: Neil
Posted 12 August 2015 - 07:56 PM
I warmed mine up as i was applying it in the middle of winter with temps in the minus range. Now as for making it smooth try a 50 50 ratio first then go from there. Cannot help with the needles too much but a 1.8 is quite large so maybe the one to use.
#4 alex-95
alex-95
  • 6,044 posts
Posted 12 August 2015 - 08:02 PM
on the bottle:
orange peel finish - U-pol gun 1 (probably a shutz gun) 40 - 70 psi
Flat finish - use neat or with max 5% cellulose thinner , ideally with a gravity fed hun, fluid tip 2.5mm, 60 - 70psi.
