In dorking surrey or post for £5 or take to MITP
£220
A random selection of mega jolt parts. Easily enough to make a setup.
Two CD's with software. One I could not get to work but you may have better luck. The other has software pictures and instructions on. You can get all this online though on autolabs website.
Coil.
Fuse holding wire.
SC parts Adjustable hub to mount a trigger wheel to A series crank pulley and tool to adjust bolt is included but not pictured.
Universal vr sensor mount.
Another sensor mount I think it's missing one part.
Couple of lengths of shielded wire.
VR sensor.
TPS sensor.
All plugs for EDIS/Coil/vr sensor. Vr sensor one wire has pulled out.
EDIS unit tested on my setup.
Mega jolt plug with spare pins.
Megajolt pc cable and com port converter.
SC parts coil crankcase bracket. ( I think this is for later coil but can be adapted for coil supplied).
6.5" 36-1 trigger wheel. Maybe a little large for A-series.
Trigger wheels two input tacho driver.
Megajolt TPS unit.
Can post for £5 will accept offers. Not to sure what it's worth. I bought two kits TPS and MAP (both used) hence selling this off as I no longer need it and why it's a little random as I selected parts from each.
