Reversing Light Wiring
4 replies to this topic
#1 johnR
johnR
  • 2,302 posts
Posted 15 August 2015 - 06:43 PM
I've put a lucas reversing light on the boot but when I put it in reverse the wires from the gearbox started melting and the light didn't come on. Should I have used a relay?
JohnR
#2 Craig89
Craig89
  • 600 posts
Posted 15 August 2015 - 08:13 PM
Sounds like you have a short circuit somewhere and the circuit isnt suitably fused. Although a relay is worth having they were not fitted as standard so the lack of one is not the cause of your problems. How exactly have you wired it?
#3 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 15 August 2015 - 11:04 PM
Have you got the light wires round the right way, accidently put power wire to light earth, just a thought, easy done.
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 16 August 2015 - 06:35 AM
What wattage is the lamp on the boot? If it is a classic Lucas unit then chances are the wires aren't big enough to carry the current draw. A relay would be the best answer.
#5 johnR
johnR
  • 2,302 posts
Posted 16 August 2015 - 07:06 AM
I used the original wiring from the gearbox to the boot, then used the same earth as the rear numberplate light. I'll have to check through it for a connector come apart or something.
The light didn't come on at all so something like that is probably the problem.
JohnR
