How Do You Earth A Mk1 Steering Column?
Posted 16 August 2015 - 11:00 AM
Any thoughts?
JohnR
Posted 16 August 2015 - 11:12 AM
There was a brass ring and a brush assy fitted to the top of the column for the Earth to the Column itself. I'll see if I can find a photo (don't hold yr breath though).
Posted 16 August 2015 - 11:32 AM
Sorry, I don't have a photo on file.
I did find a thread over on the MKI Forum;-
http://mk1-forum.net...opic.php?t=7706
I think you need to join up though to be able to see it all.
Posted 16 August 2015 - 11:36 AM
Apologies, now I look (it's been a very long while since I last looked!), that is for the Horn Wire itself.
There is an Earth Wire that does come up on the column loom, I can't recall if that's for the Horn or for the Blinker repeater bulb.
Posted 16 August 2015 - 01:26 PM
Chris, that's a great link you posted with very good photos. Nice.
EDIT: I don't remember where the black earth wire is on the steering column. Being an earth wire you should be able to add one at a location of your own choice. Just don't connect the earth wire to anything that turns or rotates.
Edited by dklawson, 16 August 2015 - 01:54 PM.
Posted 16 August 2015 - 04:02 PM
Yes, that's the problem really - it's the inner column itself that needs earthing and the only metal thing it touches is the splined stub on the rack.
Johnr
Posted 16 August 2015 - 04:07 PM
That would still leave the inner needing earthing for the horn to work?
JohnR
Posted 16 August 2015 - 05:48 PM
I hadn't given this much thought until your post. I assume the original intent was for the rack to provide the earth as you said. On my Triumphs this is what is done and they went so far as to provide an earth screw connection on the rack housing near where the pinion gear is. I image there are any number of ways to add a good earth connection to the steering rack on the Mini.
As for the little green indicator light, the original bulb socket had two wires and one of them (from memory) had a tiny ring terminal on it that attached somewhere to the turn signal switch's metal frame. In turn, the switch frame was attached to the outer column and that was earthed through the bracket attaching it to the dash rail. Again... this is from memory. It's been a decade since I worked on my car's horn and turn signal switch.
Posted 16 August 2015 - 08:24 PM
I've had a go at scraping some of the paint off the outer column where it's clamped and the clamp itself but need to do some more to get it to earth the indicator stalk light - getting there!
thanks for replies,
JohnR
Edited by johnR, 16 August 2015 - 08:25 PM.
Posted 16 August 2015 - 08:28 PM
Cheers for the comment Doug.
It's been around 30 years since I looked at one in detail, so I just resorted to the Workshop Manual, it doesn't show much at all, but interestingly, some cars were fitted with a Column Earth Wire and some were not.
Best I can determine from the Manual is that it does indeed Earth via the Rack.
I'd suggest fitting a Relay, no matter the Horn, it's just now dawned on me as to why every second rack I overhaul has a pitted bearing,,,,,,,,,,
Posted 16 August 2015 - 11:01 PM
I will second the recommendation about fitting the relay.
My Mk1's horn never sounded loud and the horn push contacts were definitely pitting quickly again after cleaning. After I installed a horn relay the high-current load was taking away from the horn push contacts and the horn is reliable and loud. The relay is easy to add and well worth it.
Posted 17 August 2015 - 12:06 AM
Doug, I hope you don't mind me taking a liberty here;-
My Mk1's horn never sounded loud and the horn push contacts were definitely pitting quickly again after cleaning. After I installed a horn relay the high-current load was taking away from the horn push contacts as well as the bearings in the steering rack and the horn is reliable and loud. The relay is easy to add and well worth it.
Posted 17 August 2015 - 11:51 AM
No problem Chris.
Posted 17 August 2015 - 05:57 PM
JohnR
