Oil/ Fluid In Driver Side Footwell
Posted 16 August 2015 - 05:20 PM
Posted 16 August 2015 - 05:22 PM
If not, it could be brake/clutch fluid or even coolant from your heater matrix.
Edited by Stiggytoo, 16 August 2015 - 05:23 PM.
Posted 16 August 2015 - 05:32 PM
Posted 16 August 2015 - 05:55 PM
As above, look for fluid drip paths under the dash. If you still cannot tell... stick your finger in the fluid and rub it between your fingers.
Oil should feel as you expect... oily.
Brake/clutch fluid should also feel oily but "thinner" and less lubricating.
Anti-freeze should also be a little oily but not nearly so much. It is much thinner and has a slippery texture more like a very thin syrup or soft drink.
Still cannot tell which it is... taste it. No, not a spoonful... just the tiniest bit on the tip of your fingers.
Anti-freeze is very sweet.
Brake fluid is decidedly bitter.
Motor oil... is oily.
And don't swallow. Spit whatever it is out of your mouth.
Posted 16 August 2015 - 06:37 PM
