Lucas Lr6 Spot Light , Not Working Can't Bin It
10 replies to this topic
#1 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 18 August 2015 - 10:21 AM
Hi all i have 1 Lucas LR6 spot light ( sealed beam ) that does not work suspect the filament has gone . I am unable to bin the light because i think there a nice looking unit . Do you think this would be of any use to anyone , like just show .
Thanks chris
#2 coopdog
coopdog
  • 4,506 posts
Posted 18 August 2015 - 11:12 AM
Pretty sure you can just convert it with a kit?
#3 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 18 August 2015 - 12:41 PM
thanks will google it
#4 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 18 August 2015 - 05:03 PM
can't find anything
#5 coopdog
coopdog
  • 4,506 posts
Posted 18 August 2015 - 07:56 PM
Hmmmm, I am sure you can convert sealed units to halogen.....
I'll have a look
#6 Cooperman
  • 23,359 posts
Posted 18 August 2015 - 10:44 PM
That's unlikely because the sealed beam don't have any sort of bulb-holding flange. It's just a glass vacuum sealed unit with a filament(s) pre-fitted. I think you may be thinking of the Lucas SLR700 'Flamethrower' spotlight which has a tungsten bulb, but which can have an adaptor to take a halogen bulb.
#7 coopdog
coopdog
  • 4,506 posts
Posted 19 August 2015 - 12:08 PM
Well I expect if your handy with a cutter and some glue I'm sure you could take a flange off another light and attach it to it if you want to keep it that bad
#8 Cooperman
  • 23,359 posts
Posted 19 August 2015 - 07:46 PM
A sealed beam unit is just a big bulb. You can't cut the back of it as it's all glass with the filament inside, just like a bulb. Break the glass and it will 'pop' just as a bulb does.
#9 coopdog
coopdog
  • 4,506 posts
Posted 19 August 2015 - 08:01 PM
im out of ideas then
#10 mk1leg
mk1leg
  • 9,343 posts
Posted 19 August 2015 - 08:35 PM
try these folks..... http://www.holden.co...g Lucas - Parts
#11 country clubman
country clubman
  • 206 posts
Posted 07 December 2015 - 10:46 AM
Thanks chris
Hi
Bit late to reply to this but I've just put a post up on how to use these and before putting up notice your question, maybe you still have them? Anyway if you have then worth a look.
http://www.theminifo...ith-wipac-unit/
