Cv Gaitor Replacement, How Do You Get The Drive Shaft Off?
6 replies to this topic
#1 The.Yellow.Mini.Guy
The.Yellow.Mini.Guy
  • 146 posts
Posted 18 August 2015 - 02:07 PM
As above,  How do you get the drive shaft off the cv? Seems pretty stuck
What this guy does but with the driveshaft being attached to the diff!
Thanks for the help, I appreciate it!
#2 nicklouse
  • 18,999 posts
Posted 18 August 2015 - 02:10 PM
Split inner CV remove drive shaft and hit CV with soft faced mallet.
#3 rally1380
rally1380
  • 1,893 posts
Posted 18 August 2015 - 02:18 PM
Yeh this is how I've always done it.....but does the above video clip cause less damage to the outer cv?  But then again possibly damages the inner splines?
Doesn't show removal of the inner cv joint does it.....must have used your method.
#4 The.Yellow.Mini.Guy
The.Yellow.Mini.Guy
  • 146 posts
Posted 18 August 2015 - 04:32 PM
Do you need to take off a circlip? I can't get my head around this.. I'm having a moment
#5 Spider
  • 15,686 posts
Posted 18 August 2015 - 08:16 PM
Dunno if this might help?
The C Clip is not externally accessible, it should retract automatically as the shaft is removed, but will (or should) need a sharp tap on the bit in green to get in started.
Edited by Moke Spider, 18 August 2015 - 08:17 PM.
#6 The.Yellow.Mini.Guy
The.Yellow.Mini.Guy
  • 146 posts
Posted 22 August 2015 - 11:55 AM
Ended up replacing the whole driveshaft, whole thing was seized  >_<
Thanks though, If only there where more sectional diagrams for these kinda things!
#7 Spider
  • 15,686 posts
Posted 22 August 2015 - 06:53 PM
Oh, in that case, it would have taken some work!
