Exhaust Decibels?
Posted 18 August 2015 - 05:10 PM
I am looking at doing an event with a 98dcb limit. I have no idea on noise decibels does anyone know roughly what a maniflow system is rated at?
Thanks in advance.
Posted 18 August 2015 - 05:12 PM
My maniflow twin box side exit is very quiet. You need to measure it to be sure.
Posted 18 August 2015 - 05:16 PM
Probably best to buy something cheap like this just to make sure
http://www.ebay.co.u...=item35d939eaf3
Posted 18 August 2015 - 06:00 PM
if you have a smart phone there are apps that can be downloaded for measuring volume. I'm not sure how accurate they are but should give you a rough idea
Posted 18 August 2015 - 06:01 PM
although a maniflow twin box will be well within that limit. I've swapped to a single box because a twin was too quiet for me!
Posted 18 August 2015 - 06:22 PM
I have a Maniflow system on mine the single box and its not that loud, the problem arises though when the sound deadning material get blown out and clogged with age, then they get louder
Posted 18 August 2015 - 07:18 PM
With a Maniflow twin-box centre exit my 'S' came in at 95 db @ 5000 rpm at 1 metre from the pipe end at 45 degrees (standard procedure). The RC40 twin box was slightly quieter at 93 db.
