Hi,
I'm starting a small bore reasonable spec engine build as follows:
lightly ported 12g295 head with standard inlets but overbore exhaust valves
1.3 Roller Rockers
Twin 1.25 SU'swith rams and pancake filters
SW5-07 cam (Purchased)
twin valve springs
A-Plus block
3.44:1 FD
Now the problem... I'm unsure which way to go, either flat top 1098 + 40tho with 1098 crank or flat top standard 998. Either way it would be using Russell Engineering Pistons operating at CR of around 10.-10.5:1 (yet to be purchased)
I'm leaning towards the 1098 but that would add additional cost at this time through the crank and block work etc. where as if I stick with the 998 I can be up and running quite quickly and possibly look to change to the 1098 later when more funds are available.
The question is... I'm looking to have the dizzy curve modified to suite the engine build, but if I go down the 998 route now with modified curve will I need to have the dizzy re-adjusted to suite the 1098 later or will the curve be the same?
As silly as it sounds the answer to the question may sway me one way or the other as changing the curve later is yet more cost!
Any thoughts would be welcome.
