Hello,
I have a straight cut clos ratio gearbox, but after rebuilt with oter casing I can not select first, third and reverse gear.
Wel second and fourth, even when the engine is running
When the engine is off, I rolled the car with low speed and when I try to select first gear it's sliding to the teeth. Its looks like of I cannot move another 3-4mm to select the full gear.
It's a lot of work to have a look in the gearbox, have anybody an idea?
Thanks a lot!
