taken a standard BL mini wiper stalk to bits to clean contacts and now cant remember how springs goes anyone here had similar issue
Wiper Stalk Spring
hillmanimpfan
, Aug 20 2015 11:14 PM
3 replies to this topic
Posted 20 August 2015 - 11:14 PM
Posted 21 August 2015 - 01:47 AM
Could possibly be a nightmare, although i have never disassembled a wiper switch i did do an indicator switch once....i ended up buying a replacement. It had multiple small springs, balls and plastic pieces
Posted 21 August 2015 - 09:37 AM
have my my stalk assembly's in bits at the moment anyway, thought i'd get you some pictures if they help at all. The back copper wire spring thing has a slight bend in it on side, put this to the top of the terminal as in the picture, there should also be 1 conventional spring which goes into the end of the stalk with a small plastic/nylon cap on the end which pushes the small piece of copper onto the terminals.
Edited by bonnieminibeast, 21 August 2015 - 09:49 AM.
Posted 21 August 2015 - 10:26 AM
thanks just what i needed get my wipers working now :) just figuring out spring was hard
Edited by hillmanimpfan, 21 August 2015 - 10:27 AM.
