White Milky Stuff Under Rocker Cover
15 replies to this topic
#1 A.Bateman
A.Bateman
  • 14 posts
Posted 21 August 2015 - 11:41 AM
I have found this under the rocker cover but haven't got a clue what it is. I'm hoping it isn't going to be too bad. What do I need to do to find out the cause? And how to fix it?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 August 2015 - 11:43 AM
Emulsification (sp?)
Usually a sign of headgasket going or gone. But can be caused by short runs and condensation.
Any signs of oil in the water or water in the oil?
#3 A.Bateman
A.Bateman
  • 14 posts
Posted 21 August 2015 - 11:44 AM
These are photos to help explain!
#4 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Looking at pics...too much for short runs and condensation. So id be looking at headgasket myself
#5 A.Bateman
A.Bateman
  • 14 posts
Posted 21 August 2015 - 11:47 AM
Ok cheers, yeah only just brought it as a project and the last owner used it occasionally and only ran it short journeys so it wasn't standing around. Would is also cause a small amount of white smoke of the exhaust with a warm engine?
Also there is no oil in the water but a tiny amount in the oil on dipstick.
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 August 2015 - 11:49 AM
White smoke is water in the combustion.
Sounds like head gasket failure to me. For cost of it id be doing head gasket with new oil and coolant.
#7 A.Bateman
A.Bateman
  • 14 posts
Posted 21 August 2015 - 11:55 AM
Okay thank you very much!
#8 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 21 August 2015 - 12:10 PM
Proper chicken soup there!  Definitely a check your HG job.
#9 Keith Staley
Keith Staley
  • 83 posts
Posted 21 August 2015 - 12:50 PM
+1 for the head gasket blown
#10 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 21 August 2015 - 01:22 PM
if it is the gasket it would be a good idea to find out why it went.
#11 midridge2
midridge2
  • 1,794 posts
Posted 21 August 2015 - 01:59 PM
Why fix something before you know its broken, do a compression check first.
#12 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 21 August 2015 - 03:57 PM
+1
#13 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 21 August 2015 - 04:02 PM
If there's no other symptoms, I'd clean that gloop out, change oil & filter, and go for a long run, driving gently. Short journeys means the engine doesn't properly get warm & shift condensation out of the oil. Likewise, white steam from the exhaust is likely condensation blowing out. See how it goes, but don't stress the engine.
#14 whistler
whistler
  • 1,818 posts
Posted 21 August 2015 - 04:33 PM
I used to have this when Castrol GTX was first released (20/50). It didn't matter whether the engine was hot or cold. Emulsion in rocker cover. Cleaned it out and went back to Castrol XL 20/50 and no more problem. Clean it out, have the compression checked and change the oil and filter. Use a 20/50, Halfords own is ok. If compression is very low then as others have said, headgasket problem.
#15 midridge2
midridge2
  • 1,794 posts
Posted 21 August 2015 - 05:09 PM
Yep. some oils are terrible at causing emulsion.
