Just thought I'd ask about these shockies before I bin them. I have a new set of the adjustable ones from Minispares and the fronts 'rattle' when driving on not so good roads. I've tried adjusting them, if you adjust them till the noise isn't apparent, they're too hard. Anything else, they rattle. I isolated it by removing them and driving without them. I can't feel anything working them by hand off the car but when fitted it sounds like half worn out shock bushes. Its becoming a bit annoying to be honest and has got to the point of maybe binning them and fitting something else. The rears appear fine although the fronts do work a bit harder than them. Just thought someone might have struck and/or solved this problem. Its a bit far to send them back from here in Aus but I don't want to get another pair to have same problem.
Gaz Shocky Noise
peter-b
, Aug 21 2015 10:27 PM
2 replies to this topic
Posted 21 August 2015 - 10:27 PM
Posted 22 August 2015 - 10:16 AM
I haven't used them before but i would send them an email and see what they can do for you to resolve the problem they are normally really helpful.
Posted 22 August 2015 - 10:19 AM
Get in touch with Simon from minispares on here, I'm sure he'll be able to help you out if they're faulty
