How Much Grease In A Radius Arm
8 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 22 August 2015 - 06:50 AM
Hi;
I am about to re-build my Radius Arms, I have a Sealy Hand Pump Grease Gun that takes a whole tube of Lithium Grease (1Kg?).
How many pumps of Grease do I need to put into the Radius Arm Grease Nipple?
#2 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 22 August 2015 - 06:51 AM
Just found this thread so I'll pump until it starts to come out of either end?
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 22 August 2015 - 06:52 AM
Yup till clean grease is visible other end. Wipe away any excess. Job done
#4 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 22 August 2015 - 06:57 AM
Will I need more than one tube?
Found this thread and it suggested several?
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 22 August 2015 - 06:58 AM
Doubt it. Theres not much space around the pin in the arm.
#6 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 22 August 2015 - 07:03 AM
Its been a known problem, that when the inner plastic tube splits, the pumped in grease ends up going into the arm cavity... you could be filling the full arm instead of just the tube around the spindle
#7 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 22 August 2015 - 08:03 AM
Hopefully it's intact :-)
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 August 2015 - 08:45 AM
You really should see the grease coming out in only a few pumps...
#9 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 22 August 2015 - 09:08 AM
If the tube is split its OK, just keep pumping, it will come out eventually. You might just need a kilo aside!
