How To Remove A Fuel Cap Cover?
7 replies to this topic
#1 The.Yellow.Mini.Guy
The.Yellow.Mini.Guy
  • 146 posts
Posted 22 August 2015 - 12:14 PM
Have one of those aston filler cap covers and I need to remove the tank to fix some rust underneath it, Can't for the life of me figure out how to get it off?
one of these ones;
http://www.minisport...-cap-cover.html
It came with the car, it seems very ebay brand..
#2 The.Yellow.Mini.Guy
The.Yellow.Mini.Guy
  • 146 posts
one of these ones;
#3 Alex_B
Alex_B
  • 4,573 posts
Posted 22 August 2015 - 12:18 PM
Likely to be three little grub screws in the neck, wind those out and remove the filler cap and the whole over cap assembly should pull off
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 22 August 2015 - 12:19 PM
There should be a few screws or  grub screws on the bit around the neck of the tank.
Edited by alex-95, 22 August 2015 - 12:19 PM.
#5 The.Yellow.Mini.Guy
The.Yellow.Mini.Guy
  • 146 posts
Posted 22 August 2015 - 12:22 PM
....that would be the small holes cover in rust, This afternoon will be fun!
#6 Alex_B
Alex_B
  • 4,573 posts
Posted 22 August 2015 - 12:25 PM
Likely yes, very small Allen key required although could be metric or imperial depends who made the cover, go easy as the grub screws don't take much to round out especially if they are rusty, get some plus gas or some other penetrating oil in there first and good luck!
#7 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 22 August 2015 - 01:30 PM
Under the catch and hinge end there should be two small hex head grub screws which you undo and then slide the cover off the cap, if it's like mine
#8 The.Yellow.Mini.Guy
The.Yellow.Mini.Guy
  • 146 posts
Posted 22 August 2015 - 04:55 PM
Thanks lads! Got it off, had to drill them out. Nightmare. Each hole had a different screw in it!
