Start from scratch. Don't assume anything is right.
You've been working on the engine... set the valve gaps with the engine cold.
Set the static timing anywhere from 5-8 BTDC to get the engine started. Do not just arbitrarily turn the distributor. I'll post a link below to my storage pages. You can download my PDF on setting static timing. It was written for points ignitions but your Aldon Ignitor behaves the same as points (as far as setting static timing) so you can follow the steps just the same.
You said you have a ballast ignition setup and the Aldon distributor. I assume this is new to the engine. There are several things that must be done "right" for this to work. I am guessing the car will only start/run while you have the key held in the start position and dies when you release the key to "run".
If you are using a ballast ignition you will have a pink/white and white/yellow wire on coil (+) and with your ignition module you will have a black wire on coil (-). Where did you connect the module's red wire? If you connected it to coil (+), that is not going to work well with the ballast wiring. You need to connect the module's red were to a switched, un-fused terminal on the fuse block to supply a full 12V to the ignition module. This is a must. Alternatively you could buy a new 12V coil and remove/bypass the ballast system.
Once you have all the above sorted, try to start the engine with modest amounts of choke. If it will run on starting fluid but dies as soon as you stop spraying... you have a fuel problem to sort out. By the way, do not keep using starting fluid, use a bit of gas tipped down the carb throat. Starting fluid sprayed continuously into the inlet has a bad reputation for washing away top end lubricants... which you don't want to do on this presumably just completed engine.
Look for my static timing PDF on the page accessed by this hyperlink.
