Sidelights Without Ignition?
Posted 22 August 2015 - 09:24 PM
Posted 22 August 2015 - 09:38 PM
Posted 22 August 2015 - 09:42 PM
Posted 22 August 2015 - 10:12 PM
You won't need the lights in the morning.
Sorry, just my sick sense of humour.
Posted 22 August 2015 - 10:26 PM
Posted 22 August 2015 - 11:15 PM
Have you looked at the actual lights?
Later Minis have a Dim-Dip relay. It's a pink box under the dash that lights the headlights a part brightness if you try and drive on just the sides.
Posted 23 August 2015 - 06:25 AM
As Ethel says later cars have a dim dip relay, so with ignition on and light switch in position 1 you should have side lights AND dim dipped beam. If you look closely you should be able to see two bulbs lit.
Posted 23 August 2015 - 08:01 AM
Posted 23 August 2015 - 08:24 AM
If you have dash and tail lights then odds on it is the bulbs or front end wiring.
Posted 23 August 2015 - 11:31 AM
