Mpi Reving
Posted 23 August 2015 - 07:59 AM
Any way forward
Thanks james
Posted 23 August 2015 - 08:25 AM
It sounds like the air control might be stuck/nutted. Try starting it up and giving it a light tap and see what happens. they can be taken apart and cleaned.
it looks like this.
http://bullmotifmini...00090_mlz100050
If it still keeps reving, take hose off valve and put your finger over hole in valve, it should drop to low idle or maybe even stop. If it still revs you possibly have an air leak in manifold. If it drops, you'll need to check further as to whether its the valve or the valve control in ecu.
Posted 23 August 2015 - 08:43 AM
If I block the pipe from the valve the revs lower to idle and if I Rev it seams all ok
Put the pipe back together and it rises again
So does that sound like a sticky valve
Thanks James
Posted 23 August 2015 - 10:48 AM
From cold it's at 1000 rpm the when warm rises to 2000 approx
If I put my finger over the pipe from the valve it drops down to 1000 rpm
Remove my finger it will rise again
Do I take the valve off and clean
Thanks again
James
Posted 23 August 2015 - 10:55 AM
Try cleaning it with spray can throttle body cleaner, you can spray intake aswell. If youre tricky you can do it with car running, although it might need throttle to stop stalling.
Posted 23 August 2015 - 11:17 AM
Posted 23 August 2015 - 11:23 AM
Nah, you need something with a bit more muscle. Throttle body cleaner desolves the cruddy carbon deposits and flushes then through to get burnt in engine.
Posted 23 August 2015 - 12:02 PM
But I have the same only way to gay 1000 tick over to the block the pipe to the valve
Do I need to reset anything ??
I'm lost now
