Capillary Water Temp Gauge Not Working
11 replies to this topic
#1 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 24 August 2015 - 08:52 PM
I have one of these gauges
http://www.minispare...px|Back to shop
The oil pressure is working fine but the water temp stopped working, the connection to the block is still good, no leaks. The car comes up to temperature fine based on the stock temp gauge in the 3 clock pod but no movement on the capillary gauge. Do these "just quit"?
Edited by bikewiz, 24 August 2015 - 08:54 PM.
#2 Spider
  • 15,236 posts
Posted 24 August 2015 - 09:19 PM
They will 'quit' if the capillary gets a leak. May not be obvious, but almost certainly, that's what it'll be. Easy to do too.
#3 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 24 August 2015 - 09:22 PM
+1 on that. Being mechanical , something has to have broke or stuck. Have you tried the magic flick of the finger repair?
#4 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 24 August 2015 - 09:38 PM
Tried the tap on the glass "why aren't you working" method and a gentle wiggle of the connection to the gauge. Checked the connection on the block which didn't pull out. If the capillary end is damaged can they be repaired?
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 24 August 2015 - 11:14 PM
I didn't realize you had posted here an on MM.  I have posted a DIY repair method for you on your MM thread.
#6 timmy850
timmy850
  • 3,412 posts
  • Local Club: MITG
Posted 24 August 2015 - 11:36 PM
I just bought a new one when I busted the tube on mine.
#7 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 25 August 2015 - 12:26 AM
Doug I usually do as sometimes the time difference works better here than there. Thanks for your response on MM.
#8 Spider
  • 15,236 posts
Posted 25 August 2015 - 01:33 AM
They can be repaired but I've not known of a DIY method. Could I trouble you guys for a link?
#9 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 25 August 2015 - 02:01 AM
I'm interested too Doug, Can you link it or C&P it here?
#10 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Absolutely.
See the link below.  I have used the method described there to fix a half dozen dual gauges.  You have to be careful not to plug the capillary tube when soldering but otherwise the method is straight forward.  The only place I deviate from the method in the link is that I use dry ice instead of the salt/water bath for chilling.
http://www.ply33.com/Repair/tempgauge
#11 Spider
  • 15,236 posts
Posted 25 August 2015 - 03:22 AM
Many thanks, cheers for that :P
#12 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 August 2015 - 11:55 AM
Oh... I forgot to mention one other observation.  Consider this a suggestion to keep you from wasting time.
If the gauge has damage to the capillary tube and/or the capillary tube is cut off, only spend your effort trying to repair it if the temperature needle is resting on its lower stop (cold).  If the gauge is stuck in any other (not cold) position, there is a good chance the instrument will need professional repair and calibration.  It's not worth trying to fix those at home.  You will only get frustrated.
