2007 Cooper S Misfire
7 replies to this topic
#1 joeyb
joeyb
    Starting My Mini Up
  • 2 posts
Posted 27 August 2015 - 08:02 PM
Hi everyone, bit of a newbie on here but after some help!!!
My Mrs has a 2007 mini cooper s, and the other day it started missfiring and hesitating. Codes came up with cylinder #4 misfire, so i've changed the coil pack and the spark plugs and still no joy.
Could this be an injector or the high pressure fuel pump?
Any help greatly apreciated thanks Joe.
#2 kyle9832
kyle9832
  • 434 posts
Posted 27 August 2015 - 08:13 PM
Dont think it will be the fuel pump mate, had this problem when working on a bmw, coils and spark plug replaced and all it turned out to be for me was that i hadnt pushed the coil pack in all the way, try taking cyl 3's coil pack off and swapping with 4 and see if the code changes to cylinder 3 misfire, if so you either have a faulty coil or spark plug, if it does not change i would be leaning more towards fuel related, i.e injector, i doubt it would be the fuel pump as you would then have a problem with all 4 mis fiering or lack of fuel...
Thats all i can think of for now! :) and welcome to the forum, this forum is mainly for classic minis but you will find people will be more than willing to give you some advice! ;)
Edited by kyle9832, 27 August 2015 - 08:14 PM.
#3 cal844
cal844
  • 9,662 posts
  • Local Club: TFMOC
Posted 27 August 2015 - 08:19 PM
Change the spark plugs then check the codes again(erase then read.. Then run the car then finally check codes a 2nd time)
Hth
#4 joeyb
joeyb
    Starting My Mini Up
  • 2 posts
Posted 27 August 2015 - 08:21 PM
Yeah i figured it was more classics when i started reading some of the forums :dontgetit:
Thanks for the advice pal, I will give it a try tommorow and see how i get on
Cheers :)
#5 OhDear
OhDear
  • 560 posts
Posted 27 August 2015 - 08:50 PM
there is another site for new minis...www.mini2. com but we are more friendly )) we brake down more so need help pushing
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 27 August 2015 - 09:06 PM
Moved to Motormouth section for non minis.
This is a forum only for classic minis, totalmini and mini2 sites have much more info for the BMW product ;-)
FS
#7 mab01uk
mab01uk
  • 12,576 posts
Posted 27 August 2015 - 10:22 PM
Link to TotalMINI.com below,
2006-2014, 2nd Gen Faults & Fixes:-
http://www.totalmini...2nd-generation/
#8 rusty30
rusty30
  • 112 posts
  • Local Club: Mini Clan
Posted 28 August 2015 - 11:56 AM
Sounds like the crank shaft sensor - had the same problem on my bini
