Hello All,
I am away at sea at the moment so don't have my mini in front of me....
I have a 7 port head (AKM) which is machined for Dry Deck usage (has no cooling ports from the block) It has the large diameter hole in the side machined to fit a dry deck kit. However my block has not been fitted with a dry deck kit before.
So as far as I am aware I need to pop out the core plug and drill and tap the mounting holes for the "flange" for the dry deck tube, also I need to drill and tap the cooling ports on the top of the block to stop the old passage of water up through the head.
I am thinking of buying the KAD dry deck kit... Anybody recommend anything else?
So basically my question is.... Can I drill and tap and do the modifications to the block with the engine in place? Or is it an engine out jobby? If I was super super careful not to drop any swarf into the cooling passages? Or is there a head gasket you can get that blocks the cooling passages on the block?
Cheers for any help in advance!!
Paul
