Help With Front To Rear Brake Pipes
14 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 28 August 2015 - 07:26 PM
Can anyone offer some advice on this please.
When fitting my subframe I pre bent the front to rear brake pipe to run it up and over the subframe (the way its supposed to go?).
Once the subframe was fitted the brake pipe is now to short to bend into place to connect to the T Piece :-(
Should I:
a. Try and pull it back through and run it under the Subframe, may damage my new paint or the pipe trying to get it out?
b. Make up some form of connector to join the pipes?
c. By a new front to rear pipe and run it under the Subframe?
Here's the pic:
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 August 2015 - 07:30 PM
With such a nice paint job there is indeed a serious risk of paint damage, up to you but I would make a short adaptor with the correct joiner which some cars use from the factory
Edited by KernowCooper, 28 August 2015 - 07:33 PM.
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 August 2015 - 07:34 PM
Put a join on it and connect a shorter piece of pipe. Shame to undo all that hard work....
#4 Spider
  • 15,142 posts
Posted 28 August 2015 - 07:52 PM
There's not much scope in the pipe to creep a bit from anywhere. If I were to put a joiner in it, I'd possibly be inclined to fit it under the floor section and make up a new shorter piece to go from there, up over and onto the subframe.
Having also been caught out on the same pipe years ago, in a similar way, While I usually make off the front of the pipe, on the back end, I make them what I think to be about 150 mm longer than they need be and not make them off until the frames are in. I ended up replacing the pipe when I did it, fortunately being a long length it didn't go to waste, but I could see from that how easy it would be to do so on the shorter pipes, so now I alsways make sure I have a bit more than what  think / measured to need.
#5 GraemeC
GraemeC
  • 7,440 posts
Posted 28 August 2015 - 08:35 PM
Make up a short male to male line and use one of these:
#6 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 29 August 2015 - 08:06 AM
Sounds like a plan but I don't have any pipe flaring tools etc and don't really want to buy any, just found the item in the picture here, it's a 3/8 UNF is that standard or is there a possibility that mine could be different?
Edited by JonnyAlpha, 29 August 2015 - 08:10 AM.
#7 GraemeC
GraemeC
  • 7,440 posts
Posted 29 August 2015 - 08:31 AM
At that end of the car, there should be no metric brake line fittings.
If you don't know anyone that can knock you one up, this should do the job:
http://www.minispare...h/classic/brake
Edited by GraemeC, 29 August 2015 - 08:31 AM.
#8 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 29 August 2015 - 08:52 AM
Looks like a solution for about a tenner - I like it, thanks Graeme.
#9 Spider
  • 15,142 posts
Posted 29 August 2015 - 09:25 AM
Grahams solution is good and it reminded me to have a look for this pipe;-
That'll screw straight on to you pipe that's too short without the joiner.
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 29 August 2015 - 09:56 AM
I thought about that too, but I felt getting a reliable seal on a copper to copper joint (without overtightening and closing off the bore) might be a bit hit and miss.
#11 Spider
  • 15,142 posts
Posted 29 August 2015 - 10:07 AM
I've done it with steel lines OK. We can't use Copper here, so I don't know. Copper to Steel should be OK.
#12 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 29 August 2015 - 11:01 AM
shoud'nt there be a loop in the pipe to allow movement of the subframe?
#13 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 29 August 2015 - 06:02 PM
Just found a pic of the rear brake setup before I removed the Subframe, yup it came over the top :-)
Geeze it looks different now :-)
Bumped into a fella today that owns a classic Mini and works in a garage and says if he can find some UNF connectors he'll make me up a pipe. A chance meeting.
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 August 2015 - 07:49 PM
I hope my subframe doesn't move that much I need a loop :ohno:
#15 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 01 September 2015 - 03:42 PM
You could always fit a short flexi hose ...
