Hole In Rear Seat Back
18 replies to this topic
#1 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 29 August 2015 - 01:16 PM
So I intend to install static 3 point rear belts using the standard mounting points. I think at some point the previous owner cut a hole in the rear seat to fit a sub :-( he has riveted an alluminium(?) plate over the hole. Is this going to be an issue for the MOT once the seat belts are re-fitted? If so can I just get someone to weld a sheet of steel over the hole?
Cheers in advance,
Steve
A4BABE63-747D-49D9-8FDC-EF8CE17EF611_1.j
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 August 2015 - 03:47 PM
I would have a piece welded in and have done with it.
You could always ask if someone could cut a piece out of a scrap shell for you to have welded in. That way, it would look like it should.
How big is the hole behind it?
#3 monkey
monkey
  • 1,382 posts
Posted 29 August 2015 - 04:44 PM
Thanks for the reply :-)
Darn I was afraid that would be the case :-(
.....anyone in Norfolk have a scrap shell and a welder?.... :-P
I don't know, I'll try and get a pic from the boot side tomorrow, if I remember correctly it's either a 10 or 12 inch circle for a sub
#4 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 29 August 2015 - 07:56 PM
Minisport sell a rear seat bulkhead (Heritage, part no. 24A2205), which incidentally has a hole in the middle - are you sure your bulkhead needs welded?
#5 monkey
monkey
  • 1,382 posts
Posted 29 August 2015 - 08:08 PM
Well the hole is definitely not a factory hole and it's not in the centre as can be seen by the pic. Like I say I'll try and get a pic from the boot side tomorrow. To be honest I was hoping it could be left as is, but as it is close to the seatbelt mount I wondered if it would be a MOT fail
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 29 August 2015 - 08:31 PM
Idealy, I'm sure you want it to be a nice ribbed rear seat back. Surely structurally the car passed an mot with the sub sitting in it, so taking a sub out would make no difference? ( at lease a riveted sheet of alloy is better than the sub!) Id whack a few more rivets in. Lets face it rivets are used on airplanes!? IMO.
#7 kyle9832
kyle9832
  • 434 posts
Posted 29 August 2015 - 08:38 PM
if you dont have a welder i wouldnt bother mate, im sure it wont be a problem:)
#8 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 29 August 2015 - 09:00 PM
If you don't want/can't weld it, get the s/hand non hole style seat section and trim it to nice round shape and pop rivet it in with the right short steel rivets. Nice coat of right colour and I doubt the inspector would notice. Do it right first time.
#9 Ethel
  • 26,580 posts
Posted 29 August 2015 - 09:26 PM
Within 30cm of a mounting is the rule for body structure, not sure if it'd apply to a belt mounting, but likely. It wouldn't be hard to make the flutes in a patch by making up a former out of some strips of plywood screwed to a board and a suitably dimensioned bit of tube to press in to them.
#10 peter-b
peter-b
  • 773 posts
Posted 29 August 2015 - 09:34 PM
Wouldn't it be easier just to get bit out of wreck, its not normally a rusted area, surely someone has an old shell with that bit intact. Hack it out with a cut off disc then trim it up with snips. Bring it round to me, I'll have it fixed in 10 minutes. :-) :-)
#11 Ethel
  • 26,580 posts
Posted 29 August 2015 - 09:54 PM
Yes, but it might not be as easy to find a donor - though perhaps a Z Car project or similar?
#12 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 August 2015 - 06:12 AM
Errrr if seats are fitted and its covered from looking inside the boot it cant fail....as a tester cannot remove items or trim to inspect. If the rear seat belts are secure not frayed etc then i cant see how it could fail unless the mot tester breaks the rules.
Right or wrong.....thats the way it is.
In terms of safety and future of the car then yes it should ideally be replaced back to standard.
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 August 2015 - 06:15 AM
I have a complete bulkhead from a scrap shell which i can sort out for you if you are not in a hurry for it.
It's in my mum's loft 100 miles away so it would have to be when i visit next
#14 monkey
monkey
  • 1,382 posts
Posted 30 August 2015 - 07:54 AM
Picture from the other side
Thanks for all the replies, to be honest I want it safe, it will be my 3 year old son and daughter (due mid November) that will be sitting in the back so don't want to bodge it through a MOT.
Sounds like welding up is the way forward, don't want to shell out for a new heritage panel, plus that looks like a lot more work!
I'm guessing welding in a patch wouldn't be a big job?
Ben - I'm in no great rush, where abouts are you located and would you be prepared to post it? (At my cost obviously!)
Thanks again for all your replies
#15 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 August 2015 - 07:59 AM
The panel is in Kent but postage is not a problem, especially if you only want that half. i can just cut it slightly oversize.
Ill be down there hopefully in a couple of months
