Subframe, radius arm and bearing are new as are the wheels. Never had this problem before with old parts and as I've said the other side sits fine. Any ideas?
Cheers.
Posted 31 August 2015 - 01:09 PM
Posted 31 August 2015 - 01:42 PM
had it set up yet?
Posted 31 August 2015 - 01:47 PM
Posted 31 August 2015 - 06:30 PM
Camber/toe brackets, although my problem is that no one local to me can do it!Not yet but didn't realise there was anything to adjust on the rears?
Edited by cal844, 31 August 2015 - 06:33 PM.
Posted 31 August 2015 - 06:41 PM
Posted 31 August 2015 - 08:10 PM
EDIT: link to parts requiredhttp://www.minisport...ontpage-nosto-1
Posted 31 August 2015 - 08:15 PM
Posted 31 August 2015 - 08:18 PM
Is the rear standard (non adjustable)?
If so I'd be taking measurements from the subframe mounting points in relation to the bodywork and where the radium arm mounts onto the subframe making sure they are the same on both sides.
Posted 31 August 2015 - 08:20 PM
Is the new subframe a genuine heritage? I've heard that this can happen with some of the copy versions!
Posted 01 September 2015 - 06:13 PM
Might just be that your bodywork isn't straight. Wouldn't surprise me if it came like this from the factory. Ideally get the alignment checked.
Posted 27 September 2015 - 05:31 AM
Any new info on this? I'm having the same problem, but no new parts, and not quite as noticeable.
Posted 27 September 2015 - 08:17 AM
Common cause is a worn / collapsed bearing and / or pin. The bearing is fitted on the inboard end.
Posted 27 September 2015 - 08:45 AM
Posted 27 September 2015 - 05:15 PM
Rear toe-in is adjustable on the rear wheels. See http://www.minimania..._up_method_1048
Have a look at page 321 and the drawing on page 322 in the Haynes manual. It shows a spacer like:
Edited by Wise Old Elf, 27 September 2015 - 05:24 PM.
Posted 29 September 2015 - 04:03 AM
Thanks, I'll give that a check.
