Advice On Carb Needle, Running To Rich
7 replies to this topic
#1 andy26nash
andy26nash
    Starting My Mini Up
  • 2 posts
Posted 01 September 2015 - 03:47 PM
I have an 850 mini with a HS4 carb. this is not the original carb and I do not know the history but has had a stage 1 kit fitted so it has a K&N filter and AAF swinging needle. The needle has a flat side not sure if this is intentional or due to wear.
The engine is running too rich, rarely needs the choke, the exhaust pipe is sooty, you can smell petrol and at MOT it was a real struggle to get it within acceptable limits. without the expense of a rolling road session I was hoping somebody could tell me what would be a good needle to try for this combination. looking to improve the economy.
Any suggestions welcome
#2 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 01 September 2015 - 04:43 PM
Have a play around on the compare-o-rama: http://www.mintylamb.co.uk/suneedle/
#3 jaydee
jaydee
  • 8,565 posts
Posted 02 September 2015 - 09:09 AM
You have to hook it up to a gas tester and set it at 3.0 CO at tickover
AAF will probably be a bit rich anyway
#4 andy26nash
andy26nash
    Starting My Mini Up
  • 2 posts
Posted 02 September 2015 - 10:29 AM
Thanks for the pointers
So looking at http://www.mintylamb.co.uk/suneedle/ just to check my understanding.
Compared to the AAF needle:
An AAQ needle would be leaner at wider throttle openings?
An AAN would be leaner across the board?
On the gas tester: when connected for the MOT even with adjusting the mixture nut could not get down to anywhere close to 3
#5 jaydee
jaydee
  • 8,565 posts
Posted 02 September 2015 - 12:27 PM
Assuming adjustment has been done correctly, if cant get close to 3.0 CO your needle and jet are both worn and need replacement
#6 carbon
carbon
  • 2,590 posts
Posted 03 September 2015 - 07:54 PM
Flat side on needle is wear, you won't be able to set idle CO and pull properly just off idle.
As Jaydee says, fit a new needle.
I would not worry about the jet, as any wear on the jet can usually be adjusted out unless really bad. And needle is a lot easier to change.
#7 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 03 September 2015 - 09:49 PM
Or maybe get it on the rollers with a decent tuner who can do custom needle work
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 04 September 2015 - 02:37 PM
And thats like finding Hens Teeth, lots will do the RR bit but those skilled enough to profile a needle are few and far between, which is why there is so many Modified Classics running around with flat spots or very weak/rich
