Hi Guys,
First of all - yes, i have checked just about everything on the vacuum system but it seems as i've missed something on my way to this point.
Problem is my MAP sensor reading is low, when engine is idling. My MAP reading says around 50-52 kPa. (Should be 30kPa)
Vacuum pipes, is in good working order.
Charcoal Canister checked
Fuel Trap checked
ECU has been opened up, and the small connecting pipe from outside the ECU to MAP sensor is also in good working order.
Brake master cylinder has been checked (2 gaskets at the front of the round plate).
Is there anything else, anywhere else i can check of there is a leak.
Could my vacuum pipes be too small in diameter, to let the "suction" in to the MAP sensor?
by the way, yes i have the SP ACR4 code reader to monitor anything i should on the engine.
Engine is 1293, 270 cam, 1.5 roller rockers, slightly modified head.
Best regards,
Jonas (Denmark)
