Alloys Centre Cap Size ?
7 replies to this topic
#1 007xico
007xico
  • 65 posts
Posted 10 September 2015 - 02:20 PM
Hi,
Got a new set of caps but they are small (54mm).
What's the size for 12 inch alloys ( 1989 Mayfair ) ?
Thanks in advance .
#2 spiguy
spiguy
  • 1,537 posts
Posted 10 September 2015 - 04:28 PM
If it's Rover 12" minilight style alloys then they should be 52mm, however as you say the 54 is too small I guess it isn't Rover minilights. In which case it depends on the wheel - what kind of wheels do you have?
#3 007xico
007xico
  • 65 posts
Posted 11 September 2015 - 09:07 AM
Hi, I attached the pic of my mini .
#4 nicklouse
  • 18,724 posts
Posted 11 September 2015 - 09:30 AM
which unfortunatly is about as much use a chocolate Teapot.
pics of the wheel would be better then details can be seen. or pop one off and have a look at the rear or even measure the hole size.
#5 007xico
007xico
  • 65 posts
Posted 11 September 2015 - 11:23 AM
Sorry for the pic.
If I measure the old ones from outside it's 56mm, the hole in the alloy it's 57mm . Really confused here as already go two sets and they are small.
Strange can't any badges for those sizes on mini spares or mini sport .
Edited by 007xico, 11 September 2015 - 11:29 AM.
#6 spiguy
spiguy
  • 1,537 posts
Posted 11 September 2015 - 10:03 PM
that looks like a Rover 12" alloy, in which case it should be a 52 mm... The proper caps have clips to hold them in place. Are you sure you are measuring the diameter of the open part - ie the actual hole size?
#7 007xico
007xico
  • 65 posts
Posted 22 September 2015 - 01:35 PM
This is becoming ridiculous, can't get the size right.
The first ones (England flag) are the old ones they measure outside 55mm/ inside 50mm (outer part of clip)
The mini ones (too small) 52mm outside/ 42mm inside
The plain ones (too big ) 56mm outside / 50mm ( similar to original but clips too thick , so won't go in )
This is becoming challenging.
#8 nicklouse
  • 18,724 posts
Posted 22 September 2015 - 02:21 PM
so have you had the wheel of to look for markings?
as they may need caps fitted from the inside.
