Ht Lead/ Spark Plug Problem
Posted 12 September 2015 - 01:19 PM
Posted 12 September 2015 - 01:46 PM
I know the fault was before you changed the dizzi , but are they both ballasted ? (coil & dizzi 9v)
clean HT system with dry rag with a bit of wd40 on it
I would suspect coil / cap / rotor arm / spark plug gaps / condition , clean coil nose - that sometimes cures weird problems & check LT leads / terminals are tight
by not directly connecting the lead to spark plug , you are upping the voltage a bit which can give a better spark
wide spark plug gaps can give rough running , if coil is weak
if the above fails to help , wait till dark , run engine , look for stray sparks , esp around coil nose , rotor cap , where leads close to engine
best of luck
Edited by sledgehammer, 12 September 2015 - 01:49 PM.
Posted 12 September 2015 - 01:50 PM
Edited by leigh21, 12 September 2015 - 01:57 PM.
Posted 12 September 2015 - 02:26 PM
No probs - hope you solve it
