Twin Bolt Subby To Single Bolt
10 replies to this topic
#1 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 14 September 2015 - 04:53 PM
Evening TMF,
Edited for clarification: Looking to fit a single bolt front subby to a twin bolt shell!
With the top mounts, will the larger bolt go through the hole in the middle of the two smaller bolts? Will anything need to be done to the shell/towers?
I know the bottom floor mounts are different, but is it a case of just drilling new holes, and reinforcing the floor?
Many thanks,
Will
Edited by Will16, 14 September 2015 - 05:35 PM.
#2 robminibcy
robminibcy
  • 1,516 posts
Posted 14 September 2015 - 05:01 PM
I think you'd be better off swapping to a single bolt. Especially as twin bolts are rarer you could stick an add up here to swap you twin bolt for a single with cash your way. That way you get a proper subby for the shell and someone else gets an authentic subby for theirs.
#3 Tomm
Tomm
  • 2,462 posts
Posted 14 September 2015 - 05:07 PM
Do you mean can you run a single bolt frame in a twin bolt cross member?
If so yes you can. I am doing it and have been for a while along with a lot of others.
Edit.
If you mean putting a twin bolt frame in a single bolt she'll and you're local to Kent,8 will come swap it for a single bolt.
Edited by tomm, 14 September 2015 - 05:08 PM.
#4 Will16
Will16
  • 1,090 posts
Posted 14 September 2015 - 05:32 PM
Sorry, should have clarified! It's a 1976 car, with a twin bolt subframe. I'm looking at fitting a single bolt subframe to it (albeit not instantly) for a conversion.
Basically I'm asking, is a lot of work required for fitting a single bolt subby to a twin bolt shell? Just the turrets and bottom mounts, engine/gearbox won't be a series!
Edited by Will16, 14 September 2015 - 05:34 PM.
#5 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 14 September 2015 - 05:39 PM
What benefits do you see of a single bolt subframe over a twin bolt subframe?
#6 Tomm
Tomm
  • 2,462 posts
Posted 14 September 2015 - 06:09 PM
A lot of people opt for single bolt frames and ask this question as all speed only offer modified frames for engine conversions in single frame fitment.
#7 Will16
Will16
  • 1,090 posts
Posted 14 September 2015 - 06:40 PM
Exactly that ^^^^. I'm looking at buying a engine conversion subframe, but it's for a single bolt car! I'm not doing a conversion this second, but it's on the cards, and the frame is going pretty cheap.
#8 Tomm
Tomm
  • 2,462 posts
Posted 14 September 2015 - 07:12 PM
16v shop only sell single bolt frames. I enquired and was told that there are many people running the single bolt frames in earlier twin bolt cars.
I enquired on various other forums and got a lot of good responses before I did it myself.
Now I am doing it, no problems to report.
#9 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 15 September 2015 - 09:07 PM
Everdays a school day :-)
If you supplied your exixting twin bolt - would they modify that?
#10 pinkmini99
pinkmini99
  • 563 posts
Posted 16 September 2015 - 05:53 AM
I've seen it done. I have a twin bolt subframe in my clubby but my pickup is single and there is a strengthening tube in the bulk head on the single bolt so you mite crush the crossmember.
#11 Ethel
  • 25,996 posts
Posted 16 September 2015 - 08:17 AM
..also reinforcement plates on the toe-board and slight differences (hole location)for the front mountings. Nothing too major compared to doing an engine conversion.
You could make up some plates, with a spacer tube, to sandwich the cross member; using the original twin bolts and in place of the the big bolt rubbers.
