Starter Relay
Best Answer nollyd , 17 September 2015 - 03:40 PM
just a quick update guys,had to replace 5 wires in loom,ignition switch too.found that whilst running if i pressed on the back of the ignition switch it would stall.also after checking on the info you all gave me realised i had been sold the wrong coil.on replacing it then putting in the restrictive bypass wire was all good,replaced the starter relay too as it was badly corroded inside..one good thing is the car is now in new condition where ignition side is concerned as leads,coil,plugs,rotar arm,dizzy cap,fuel pump have all been replaced too.
one last thing to do is thank you all sooooooo much for your help and advice,knew i could count on you.
Go to the full post
Posted 17 September 2015 - 05:24 AM
So hopefully ive found the problem.starter relay under bonnet on clutch side inner wing.ive got a new one coming today but just wanted to know if this relay could cause these sort of symptoms.and what could cause this relay to break.it does look like the original to be fair so 28 years isnt too bad really.
Posted 17 September 2015 - 05:43 AM
Starter relay is only active when the starter switch is engaged, so I can't imagine that this is the cause of cutting out after the engine is running.This relay usually fails due to the 2 big contacts inside getting eroded due to use.Sounds like the coil may be getting overheated and failing after 10 minutes.Are you sure it is an electrical problem, and not fuel?
Posted 17 September 2015 - 06:17 AM
Posted 17 September 2015 - 07:11 AM
Posted 17 September 2015 - 07:22 AM
Posted 17 September 2015 - 08:11 AM
a loose wire somewhere.
blocked tank breather.
failing fuel pump.
anything.
Posted 17 September 2015 - 10:00 AM
As Pointed out by Nick above "Anything" to find out you need to do a full engine tune and check of all components of the Ignition system checking voltage at the coil and work your way through it, It won't be the starter relay as its not connected to anything that controls the running of the car. As soon as it stops out with the voltmeter and check Coil Voltage, ohms between the + & - terminals and then check for spark at the plugs. If you still have spark at the plugs when it stops then its fuel related.
Posted 17 September 2015 - 10:38 AM
Posted 17 September 2015 - 10:47 AM
We're referring to the starter solenoid, rather than the relay aren't we? (big thing on the inner wing with a thick cable from the battery and to the starter and smaller wires coming off it)
Loss of power here would cause the car to cut out, I'm just not sure what would cause the symptoms you're describing.
Posted 17 September 2015 - 12:08 PM
Yes and no. The main battery feed cable from the rear of the car will go to one of the threaded posts on the solenoid. A whole bunch of the car's "brown" wires attach to that same threaded solenoid terminal. IF you have loose contacts between the brown wires and main battery feed cable you could lose some circuits or those circuits could come and go with vibration. However, a failed or failing solenoid will not cause the problems reported. A failed solenoid would just prevent the engine from turning over on the key.
Posted 17 September 2015 - 03:40 PM Best Answer
Posted 17 September 2015 - 04:21 PM
I am glad that you were able to sort out so many issues and will be on the road soon.
For future readers of this thread be aware that the starter relay and the starter solenoid are not the same thing. On Minis with the pre-engaged starters a separate, small starter relay is used to power the solenoid on the starter motor. This was necessary as the pre-engaged starter solenoid draws too much current through the ignition switch contacts for the starter.
Posted 17 September 2015 - 04:34 PM
ive learnt so much these past few days thanks to you guys.
