Dash Mounted Electric Fuel Pressure Gauge Advice Needed
8 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 20 September 2015 - 07:12 PM
Looking to get a dash mounted fuel pressure gauge I am interested in this one ( https://www.merlinmo...auge-cbc-fpe-10 ) but they say it needs the correct smiths sender unit.
Is this all i need ( https://www.merlinmo...sender-cbc-ft-1)
and just tap it into the fuel line?
Edited by HUBBA.HUBBA, 20 September 2015 - 07:13 PM.
#2 nicklouse
  • 18,998 posts
Posted 20 September 2015 - 07:42 PM
HOW much for something you don't need.
But yes they seem to show that they are both needed to work together.
#3 Spider
  • 15,685 posts
Posted 20 September 2015 - 09:03 PM
They can be a useful gauge, certainly a must with higher powered engines as a drop in fuel pressure can result in a high speed lean out and an expensive rebuild. I haven't seen it happen on a Mini, but I have seen it happen on 2 other competition engines, ruined the pistons in both of them.
It does seem an expensive set up, though maybe warranted.
#4 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 20 September 2015 - 09:12 PM
Do you think the sender just taps into the fuel line?
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 20 September 2015 - 09:14 PM
I won't be paying that. Just put these up as an example. I'll get the gauge direct from CAI
#6 Spider
  • 15,685 posts
Posted 20 September 2015 - 09:25 PM
Yes, with a Tee and I'd suggest fitting it as close to the carb as you can get it.
#7 nicklouse
  • 18,998 posts
Posted 20 September 2015 - 10:13 PM
But still not really needed. You would do better with pump(s) that can supply the fueling you need but then have a regulator close to the carb(s) so as not to cause the float to be over powered.
A cheap inline gauge in the engine bay can be good for set up.
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 28 September 2015 - 09:29 PM
Decided on having an adapter permanently inline with a blanking screw and I can still use my sytec gauge as and when setting up.
#9 nicklouse
  • 18,998 posts
Posted 28 September 2015 - 09:31 PM
Sounds like a plan.
