Hey guys, a previous post of mine talked about my idle problems on my SPI mini, but having renewed and rebuilt the entire injection system, i'm living with it.
Good news- the car is pulling and driving better than ever after fitting a genuine Bosch lambda, genuine Rover/MG coolant sensor, new throttle sensor genuine, new air temp sensor and Maniflow LCB.
Now, I've another small issue that i hope someone can explain...
The car warms up as usual, dropping revs until the temp gauge shows just below half. PERFECT!
But on driving the car the temp hand moves up slightly to half way then slightly above the black line.
When I pull up at lights, it drops again to just below half, which is were it sat before I did the injection work. I;ve never seen it move this much from below mid, mid then slightly over mid and back down.
The thermostat has been replaced and checked, coolant sensor new (Genuine MG part), new fan, rad is minispares 2 core, coolant is soft water 50/50 with green coolant.
I've never seen it move so much, I've flushed the system twice, bled it and checked for leaks etc but everything looks fine.
Has anyone seen this before?
