Bmc Works Rally Manifolds And Exhausts
8 replies to this topic
#1 86mayfair
86mayfair
  • 557 posts
Posted 25 September 2015 - 06:36 PM
Hi folks,
This is one for the rally enthusiasts and historians amongst us. There are 3 reproduction works exhausts on the market that I can see: two from Maniflow (one crimped, one oval), and one from Somerford (oval).
Is the Somerford one the same exhaust as the one made by Maniflow? It says that it is "made for Somerford Mini by the original supplier to Special Tuning"
My next question is what diameter are they, and will they fit onto a Maniflow Cooper Freeflow manifold? Or will I need the little adapter if they're the same diameter?
#2 MiniGulf
MiniGulf
  • 17 posts
Posted 25 September 2015 - 06:54 PM
Hi there I have the works replica exhaust on my mini I bought it from somerford mini the system is round not oval if this helps, also I can give you the measurements tomorrow if that's helps thanks richard
#3 86mayfair
86mayfair
  • 557 posts
Posted 25 September 2015 - 07:08 PM
That would be a major help, thank you! Do you know which exhaust manifold you have? And also, just what do you think of it in general?
#4 Cooperman
  • 23,286 posts
Posted 25 September 2015 - 07:14 PM
There were many different manifolds used by the 'works' rally cars over the years.
The early Mk.1 Coopers had the crimped manifolds, then along came the Cooper 's' and they had a simple 3-branch followed by the LCB.
Of course, whether they were running in Group 1 or Group 2 made a difference as well.
I guess you pay your money & take your choice really.
#5 86mayfair
86mayfair
  • 557 posts
Posted 25 September 2015 - 07:22 PM
Thanks, I realise there was a lot of evolution over the years they were competing. Is this like the simple 3 branch manifold you mentioned?
#6 MiniGulf
MiniGulf
  • 17 posts
Posted 25 September 2015 - 07:32 PM
Hi there this is the set up that I have on my mini, LM004S11R made by maniflow stage2 lcb
STR807 Maniflow Saloon ‘Works’ System, it sounds amazing well happy with it, if this helps.
#7 86mayfair
86mayfair
  • 557 posts
Posted 25 September 2015 - 08:02 PM
Thanks very much  :-)
#8 Spitz
Spitz
  • 1,716 posts
Posted 25 September 2015 - 08:26 PM
This was the original  Cooper(S) manifold.  Not sure if the Works cars used them however
Edited by Spitz, 25 September 2015 - 08:32 PM.
#9 Cooperman
  • 23,286 posts
Posted 25 September 2015 - 08:34 PM
Yes indeed, that's the crimped one and I had one of those on my then-new 1964 998 Cooper. I remember it snapped at the lower bend and had to be welded up. The tubular ones are much stronger.
