Strobe Timing Light Cutting Out Engine
Best Answer minidave54 , 26 September 2015 - 08:08 PM
Thanks for all the replies.
Connected up the timing gun with the induction lead to the No1 plug disconnected, and when operated it made no difference to the engine revs.
Then used Kernow's suggestion and used a spare battery for the power and earth, and all worked fine.
Still don't know what caused the initial problem, but I have managed to check my timing.
When time allows I will do some further investigation and try and find the cause of the problem.
Go to the full post
9 replies to this topic
#1 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 25 September 2015 - 07:37 PM
Hi All, I have been trying to check the ignition timing using my strobe light. The vacuum advance hose has been disconnected and blanked.
The strobe leads have been connected one to the engine for an earth and the other to the battery pos lead on the starter motor. Induction lead on No1 plug lead
Revs put up to 1500. But whenever I press the button on the strobe to check my timing the engine revs die and the engine almost stalls.
By releasing the button the engine recovers.
Has anybody come across this problem before. Need to get the timing checked
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 September 2015 - 07:49 PM
Nope not seen that before ? the pick-up is impulse type so remove the connection off no1 plug and try then you will know which circuit it is, unless your leads are shot and the gun is drawing what little spark you have away but you'd think it would just misfire on cyl 1? Try a new 12v feed point for the timing gun, slave battery?
Edited by KernowCooper, 25 September 2015 - 08:29 PM.
#3 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 25 September 2015 - 11:14 PM
I had a 1098 that ran on two cylinders .. Not well but it ran! (damaged valves)
#4 fenghuang
fenghuang
  • 796 posts
Posted 26 September 2015 - 06:53 AM
+1 for Kernow's suggestion.
Does the trigger have the same effect with the clamp not on an HT lead?
Does it happen with the clamp on different HT leads? (You can't easily set the timing this way, but it should help narrow down the problem with the timing light.)
#5 CityEPete
CityEPete
  • 3,920 posts
Posted 26 September 2015 - 07:28 AM
That is a good one, well done for finding a new problem!
I wonder if the gun wires are going dead short when you pull the trigger in? If you try feeding the gun with the 12V from a battery charger or a slave battery I wouldn't be surprised if it either blows the fuse in the battery charger or the gun wires just get really hot when using a slave battery but the car then will not faulter as you do it, that would be my guess.
Edited by CityEPete, 26 September 2015 - 07:28 AM.
#6 CityEPete
CityEPete
  • 3,920 posts
Posted 26 September 2015 - 07:31 AM
My gun will not activate without a pulse coming in so that might not prove much, although if it is shorted out inside then it might get hot if he pulls the trigger in for a while as you say.
#7 Rob1234mini
Rob1234mini
    Just On Tickover
  • 5 posts
Posted 26 September 2015 - 07:49 AM
Try a different 12v feed for the light also check for a good earth its sounds like your creating your own circuit which is taking the power from the coil
#8 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 26 September 2015 - 09:11 AM
If it is going full short when the trigger is pulled, it may be easier and safer to test for a short with a multimeter rather than see if it all gets a bit hot
#9 CityEPete
CityEPete
  • 3,920 posts
Posted 26 September 2015 - 02:35 PM
As there is supposed to be a circuit across red and black anyway and possibly only when a trigger pulse is being induced it's not going to be easy to test that way imo, if you use a battery charger as I said before it will pop the output fuse, if it does it's new strobe time.
#10 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 26 September 2015 - 08:08 PM   Best Answer
