Lower Ball Joint Spacers.
24 replies to this topic
#1 nicklouse
  • 18,601 posts
Posted 28 September 2015 - 07:34 AM
now i am looking to to buy some of these.
does anyone have a link that i can click on and buy some.
it is a shame some companies making it hard to buy their products.
#2 A-Cell
A-Cell
  • 1,610 posts
Posted 28 September 2015 - 08:13 AM
If you mean the shims then Minispares sell them separately
http://www.minispare...41.aspx|Back to
#3 nicklouse
  • 18,601 posts
Posted 28 September 2015 - 08:21 AM
Nope spacers. not a thing that Mini spares do.
they move the balljoint lower.
#4 A-Cell
A-Cell
  • 1,610 posts
Posted 28 September 2015 - 08:31 AM
Not seen any for sale for many many years. You might try Swift tune.
#5 phil hill
phil hill
  • 616 posts
Posted 28 September 2015 - 08:48 AM
Leigh Dale at Mondosport, KAD, or Endaf Owens at Owens Fabrication.
Maybe others who supply or support Miglias, perhaps SHEngineering, MED or the like can help ??
Phil.
#6 nicklouse
  • 18,601 posts
Posted 28 September 2015 - 09:02 AM
Phil.
sure but i am fed up with the waiting how long and how many Email/messages does it take?
hence the request for a clic and buy.
#7 Tupers
Tupers
  • 4,149 posts
Posted 28 September 2015 - 09:18 AM
You can just about see them on here at the bottom of the pic.
These are the type that Mondo Sport sell but I'm yet to see them appear on a retail site.
#8 Spider
  • 14,895 posts
Posted 28 September 2015 - 09:25 AM
Nick, have you sent Adrian at KAD an email? I'd find it surprising if he hasn't been back to you, even if the answer is no, after a few days. I know he does get busy from time to time, so be a little patient.
#9 nicklouse
  • 18,601 posts
Posted 28 September 2015 - 11:41 AM
to be honest KAD were not on my list as they dont list them and the time they took getting back to be about the Arches.
and as they do the Metro threaded hubs they can just drop in an MGF ball joint to do the same.
#10 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 28 September 2015 - 11:49 AM
Obviously all of you are familiar with these items... I am not.  What do they do?  What change/advantage do they offer?
#11 Alex_B
Alex_B
  • 4,573 posts
Posted 28 September 2015 - 11:52 AM
I believe leigh dale deals with KAD regularly so if you can't get through to him then they may be able to put you in touch.
#12 smudger068
smudger068
  • 344 posts
Posted 28 September 2015 - 11:58 AM
i will be interested to see if you can find these on click and collect type thing as i spent ages before.
When Minis run as low as some do it puts the roll center and the geometry out.
These spacers therefore put the lower arms at a correct angle so an ideal center can still be maintained.
#13 nicklouse
  • 18,601 posts
Posted 28 September 2015 - 01:10 PM
they can do a number of things.
as you lower a Mini a number of things happen.
the front roll center goes under the ground plane.
and the lower "Triangle" starts adding positive camber.(or does not add as much negative camber) these things can be changed by reloacating the pivot points (not easy in most cases) the easiest is the lower ball joint.
it also does other things as well depending on the height of the spacer. (caster and kingpin angle will change).
#14 cooperS
cooperS
  • 116 posts
  • Local Club: MOC Santiago, Chile
Posted 29 March 2017 - 12:28 AM
thread revival, got my ball joint spacers, but my Q is, how do I fit the lower ball joint spring? the spacer has a hole inside and the spring does not sit on the spacer.....
how do you do?
#15 Dusky
Dusky
  • 5,322 posts
Posted 29 March 2017 - 02:33 AM
https://www.upaclick...-adjusters-rcas
