Front Shocks Pin Nightmare
5 replies to this topic
#1 Buckles23
Buckles23
  • 108 posts
Posted Yesterday, 07:21 PM
Hey
Noticed one of my front shocks leaking so decided to swap them over with new ones… another 20min job that turns into a full afternoon.
Removed old shocks and rubber bushes had stuck onto the pin.. cut off the rubber to leave the steel insert and used a bolt extractor to loosen and removed.. took ages with some success but last one obviously was the right pain.. top pin on drivers side. Ended up snapping the bolt clean off just where the shocks sit…
Has anyone been in this position.. what’s the best way to deal with it before a destroy anything else.
Does the bolt just knock out or is it welded in there or something.. noticed u can get bracket and bolt together and wasn’t sure if its all one bit..
Any tips would be grateful
#2 Tupers
Tupers
  • 4,149 posts
Posted Yesterday, 07:27 PM
The damper bolt isn’t welded or threaded into the top arm but they do love to rust in place.
A bit of penetrating fluid and a big whack with a hammer and pin punch normally gets them moving.
#3 Buckles23
Buckles23
  • 108 posts
Posted Yesterday, 07:42 PM
Thanks.. I’ll give that a go then
#4 absx2
absx2
  • 916 posts
Posted Yesterday, 08:36 PM
Nine times out of ten when you remove the top mount to replace it you find a load of rust as well !
But we still love them :)
#5 mab01uk
mab01uk
  • 12,431 posts
Posted Yesterday, 09:27 PM
Do you mean the top shocker mount here:-
https://www.minispar...ont-bracket-r-h
or the pin in the top suspension arm?
Edited by mab01uk, Yesterday, 09:27 PM.
#6 Buckles23
Buckles23
  • 108 posts
Posted Today, 06:48 AM
Yes it’s the top mount you have on the link, which connects to the shock. The pin has broken off. The pin at the bottom is ok.
