I've bought some adjustable lower arms and set up my suspension:
1.3 degree negative camber
3.3 degree castor
Went to take it out for a test drive and when reversing the front was juddering as if a drive shaft wasn't engaged - looking down from the top the drivers side was near fully out.
I jacked it up and and supported the car whilst I lifted the drivers side wheel - you can clearly see the inner drive shaft coming away from the CV joint as you jack up the wheel using the bottom ball joint.
image.jpg 59.62K
57 downloads
image.jpg 64.27K
50 downloadsI know that adding negative camber would bring the wheel and drive shaft away from the I inner CV joint but enough for it to come out?
I'd understand if it was scraping the tarmac but it's not lowered excessively: 275mm to the sill at the rear, 255mm to the sill at the front. The driveshafts are almost horizontal.
Any ideas? Didn't know if I could've forced the driveshaft too far into the outer CV end?
Cheers,
Ian
Edited by Smackfiend, 03 October 2015 - 09:31 PM.
