Rubber Glue Stuff Behind Arch
Posted 04 October 2015 - 12:40 PM
Posted 04 October 2015 - 12:53 PM
Have you tried oil, like baby oil or WD40, should soften it and make it easier to pick or gently scrape off.
Posted 04 October 2015 - 01:03 PM
Try panel wipe. You can remove little bits with a carmel wheel.
Posted 04 October 2015 - 01:11 PM
Hot air gun and a credit card style scraper. a product like Autosmart tardis will disolve the rest.
Posted 05 October 2015 - 11:10 AM
Thats silicone sealant by the looks of things.
Therefore theres no compound or solvent capable of loosening it sadly....
However, in my experience, if you take a windscreen ice scraper to the bulky parts, and then using a dry cotton rag, if you rub at it firmly, it will peel it away.
It takes a lot of effort but it will peel off eventually.
Obviously a plastic ice scraper will mark the paint, but if you go carefully and keep in the radius of the wheel arch fitment, you should be fine with a little t-cut after youre finished.
