The only thing in the oil system changed is a new pump and oil filter
The engine hasn't been touched and wasn't having this issue before:
The first day of running the engine after lifting it back in had no problems but the other night came to move to the car in front of the house and the oil pressure light wouldn't go out so I turned the engine off immediately waited a second or two and then tried another 3 times without luck to get the light to go out so I was at this point worried sick so decided to fit a gauge to see of the pressure sensor was faulty so I did that the following day.
After having fitted the gauge and adaptor so I can have the sensor in aswell started the engine and the light was on again and the gauge at 0 but then it came alive and went to nearly 100 on tick over now I know this is too high but a tee driving IT abit it has settled down to about 55 on tick over and about 80 at about 70mph
But the strange thing is the light has been going out almost instantly now after starting butnthe gauge is still showing 0 for a good 10 seconds before going up to 55 wondered if this was because of the pipe being 5ft long
But it's changed again now because the pressure light has started flicking now before the gauge builds up all this is making me think the relief valve is playing silly buggers possibly working and not working just a little concerning
It's actually a very good engine and I have looked after it regular oil and filter changes of castrol 20/50 with a can of winns too
The engine has just shy of 115,000 miles on it
Also ginna try a new oil pressure sensor aswell as cleaning the relief valve plunger
Edited by Jake Didsbury, 04 October 2015 - 07:03 PM.
