Wiring Up The Amp & Oil Gage Via A New Dash?
9 replies to this topic
#1 RichMPiBlue
RichMPiBlue
  • 474 posts
Posted 08 October 2015 - 05:37 PM
Hi,
A few months ago I added a new RHD blue/black vinyl dash to my mini and it now has 3 dials. Does anyone know how to wire up the amp and oil gage?
Thanks,
Rich
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 October 2015 - 08:45 PM
Not many use a amp meter now, as the alternator outputs have risen and it means a large amperage cable coming in from the main brown
being removed from the starter soleniod going into the amp meter and a return going back to where the Brown was removed from. It means having 2 additional wire coming into the cabin and being 100% insulated from the body, if the amp meter dies the car is dead on power. Most now and what I recommend you fit in its place is a volt meter, this will tell you everything you need to know, it requires a switched live, a earth and a feed from the side light circuit for the illumination.
Oil pressure gages are fitted with a T Piece onto the Oil Pressure switch and the nylon or braded steel line brought into the car and onto the gauge, needs a earth and a side light feed for illumination
Edited by KernowCooper, 08 October 2015 - 08:47 PM.
#3 RichMPiBlue
RichMPiBlue
  • 474 posts
Posted 08 October 2015 - 10:04 PM
My mini is an MPi '98 as its modern ... so the engine is very compact. This means striping the lot down to wire two gages up don't it?
Edited by RichMPiBlue, 08 October 2015 - 10:06 PM.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 October 2015 - 10:41 PM
No not at all the voltmeter connection is done inside the dash area, and the oil pressure gauge just needs a small bore pipe bringing back into the cabin
#5 RichMPiBlue
RichMPiBlue
  • 474 posts
Posted 09 October 2015 - 09:51 AM
Where do you tap off from the engine for the oil?
#6 JetBlackEreg
JetBlackEreg
  • 130 posts
  • Local Club: East Anglian mini club
Posted 09 October 2015 - 01:58 PM
Oil pressure sender in the top left of the block.
#7 carbon
carbon
  • 2,590 posts
Posted 09 October 2015 - 04:40 PM
As Kernow Cooper says, the ammeter has to be installed using cable capable of taking full current. For modern Minis that could be 60 amps or more?
If the cables to the ammeter are too thin there is a risk they will overheat, melt, and possibly start a fire.
#8 RichMPiBlue
RichMPiBlue
  • 474 posts
Posted 11 October 2015 - 03:35 PM
Do you know of any videos or websites showing how to wire up the oil and amp gages?
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 October 2015 - 11:01 PM
None I know of regarding sites with the info, it would have to be info we advised on here, and you would need god wiring skills to make it safe, but I;d not go down the amp meter route for the reason above, and would you amp meter take 60amps
The gauge is a process of unscrewing the oil pressure switch, screwing in the T Piece and then fitting the oil pressure switch in the end of the T Piece, then connect the supplied pipe to the T Piece, run it into the car being careful to gromett the hole and connect it to the back of the gauge.
Edited by KernowCooper, 11 October 2015 - 11:09 PM.
#10 RichMPiBlue
RichMPiBlue
  • 474 posts
Posted 14 October 2015 - 08:34 PM
I will try that. Thank you for the information.
