Spi Fuel Tank Removal
2 replies to this topic
#1 bangermadness08
bangermadness08
  • 262 posts
Posted 09 October 2015 - 11:43 PM
hi peeps as title says really im doing a resto on my car and im doing the back now i need to remove the tank because of welding cutting e.t.c but ive never removed a fuel tank before and would like to know from you guys whats the best method and the safest way and aslo where to store the empty tank safely pics if any would be great just would like to know the best way in doing so the tank is about half full so how would i go about draining it
sorry that was alot i just wanted to cover everything thank you :)
#2 brivinci
brivinci
  • 1,195 posts
Posted 10 October 2015 - 04:40 AM
I have t removed mine in ages but have had to move it out of the way of left shock. Once the tank is moved towards the center of the boot, getting to everything else is much easier.
To do that, first remove the large plastic fuel sender guard that is on the side of the tank. It's held on by two "firn-tree" things. Once off, you will see the fuel level sending unit with two wires going to it. Removed them. They are two different size blades so you can mix them up. With that done you just need to removed the super long bolt at the bottom, right near the lower left corner of the boot opening. That holds the tank securing strap tight. Once that is removed you can pull the tank strap out of the way and the tank is free. Remove the gas cap and then start to wiggle the tank towards the center of the boot. Once you clear the petrol neck from the body, the tank can sit in the spare tire well. Makes getting to the various pipes and connections much easier.
As for removing fuel, I'd like to know that as well. You could disconnect the line at the fuel filter (bolted to the inner left side of rear subframe) "in" side and have the fuel pour out. You will need a large catch all around the area as well as a can to fill with the fuel coming out. Due to the location of filter, there is a good chance of it going on the subframe and missing the can you have to fill, hence the large catch under it.
#3 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 10 October 2015 - 03:09 PM
This is for the MPI but the SPI is similar:
http://www.theminifo...attach_id=68239
Page 141 of the PDF has the tank draining (not very useful) I drain the tank with a flo n go hand pump http://www.amazon.co...p/dp/B003TG9J36
Page 143 of the PDF has the tank removal
