Dashpot Oil In Turbo Carb
3 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 10 October 2015 - 07:11 PM
I normally use standard su oil but is there a specific oil of turbo hif44's. Please note this is for a super charger application
#2 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 11 October 2015 - 09:25 AM
I used to use millers 20w50 the same as the engine. I also used a strong Spring. The car was setup on the rollers like this.
I Found when I moved to a bike carb which used a diaphragm, the fueling was much more consitant. I guess as the oil in the carb get hot its flow changes, if the piston lifts too quickly your more likely to get a lean spot
#3 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 14 October 2015 - 09:20 PM
#4 timmy850
timmy850
  • 3,340 posts
  • Local Club: MITG
Posted 15 October 2015 - 02:04 AM
If you find the oil changes the tune with temperature, try a straight 20W oil like the SU brand oil.
