Classic Mini 998 1986 'D'
I bought this little mini as a project. It started life as a 998 automatic. In true stereotypical automatic ownership, it had previously been owned by several old ladies and well cared for, with a genuine 60,000 miles. I then bought a 998 manual Mayfair with a rough body, but sound engine. The engine has covered a genuine 65,000 miles, so very close to the mileage on the clocks. The Mayfair was used as a donor car to convert from automatic to manual, with many new parts used. 100's of man hours and £1000's have been spent to get this little mini up to the very high standard you see today. The mini has only covered 100 miles since completion, but I've had my fun and it's now time to sell it on and let somebody else enjoy this lovely little thing.
MOT 7th June 2016
Mileage 60,000 (Mini driven only 100 miles since restoration completion)
BODY:
1986 Red/white classic mini
The mini is 99% rust free. The floors,sills, and subframes are all solid. The exterior bodywork is extremely clean with only the odd tiny bubble here and there.
New British Heritage front end including bonnet, and resprayed in the original colour within the last couple of years by previous owner.
Paint professionally detailed and corrected, and protected with a sealant
Chrome wipers and washers
Chrome bullet mirrors
Brand New (B/N) Front windscreen/rubber/chrome inserts.
B/N Rear quarter light rubbers
B/N Cooper decals/pin stripe
B/N Cooper Badges
B/N Chrome front/rear bumpers
B/N Mini special arches/rubber
B/N Chrome number plate light
B/N Chrome door lock set
B/N GB badge
B/N Petrol cap / rubber seal / BH tank
B/N Number plates
B/N Clear indicator lenses
ENGINE:
The engine / bay has been cleaned and painted, with fresh fluids, new gaskets, and many new parts fitted. So clean you could eat your dinner off of it.
It was then professionally set up by a mini specialist and now runs like a dream.
998 manual engine (Stage one kit fitted)
Maniflow exhaust
B/N Oil/filter
B/N Coolant
B/N Brake/clutch fluid
B/N K&N Filter
B/N HT leads and spark plugs.
B/N Fan belt
B/N Water pump
B/N Thermostat / studs
B/N Gaskets where needed
B/N Alternator
B/N Fuse box and all new connectors.
B/N Coolant temp sensor
B/N Oil pressure switch/sensor
B/N Clutch master cylinder
B/N Clutch slave cylinder
B/N Clutch hose and cooper pipe.
B/N Engine earth straps and battery strap.
WHEELS / SUSPENSION
5x12 minilights
Very good condition Falken tyres
Standard suspension
INTERIOR:
The interior has been completely stripped and all new fitted in black.
B/N Black headlining
B/N Carpet
B/N Over mats
Seats re-trimmed in high quality vinyl and B/N foam
B/N Door cards
B/N Alloy door furniture
B/N Cooper gear knob
B/N Handbrake handle
B/N Leather gaiters.
Genuine Cooper steering wheel
B/N Pedal rubbers
B/N Dash inserts
B/N Parcel shelf board
B/N Boot Carpet
B/N Door seals and rubbers
Black seatbelts
Black dash rails
£5800
The mini is based in Shorne, Kent, DA12, 10 mins from Bluewater.
Please feel free to text or call Jamie: 07985 166425
