Driver Side Wheel Sounds Like Roller Skate Wheel?
9 replies to this topic
#1 lee84
lee84
  • 79 posts
  • Local Club: West Mids Mini Owners Club
Posted 12 October 2015 - 02:14 PM
HI Guys
Last week or so there is a noise coming from my driver side front wheel when driving, best way to describe it is like holding a roller skate up and spinning the wheel? im a bit of a novice mechanically but im guessing a wheel bearing problem? Any feedback would be appreciated
Lee
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 12 October 2015 - 02:20 PM
Wheel bearing.
Jack it up and spin it, try and rock the wheel by holding it at 12 and 6
#3 lee84
lee84
  • 79 posts
Posted 12 October 2015 - 02:29 PM
Wheel bearing.
I thought so, problem is its my daily and cant get in garage until next week, can it cause any long standing damage if not fixed asap? only about 6 mile round trip to work so not driving far?
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 12 October 2015 - 02:34 PM
Wheel bearing.
It could cause the wheel to lock up, it could damage the hub if the bearing spins in the hub.
Check the hub nut hasn't come loose, if it has the bearing will still need replacing, but you'll have a cause.
#5 spiguy
spiguy
  • 1,537 posts
Posted 12 October 2015 - 03:52 PM
Could well be wheel bearing, although a bad bearing often produces a low grumbly sound, which changes with speed. Could also be dragging brakes.The sound of a brake pad scraping the disc all the time could possibly be described to be like a roller skate wheel sound. Incidentally, that stereotypicall roller skate sound is caused by cheap bearings. A good set of SKF bearings in your rollerskates and it wouldn't make any sound at all ! :lol:
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 12 October 2015 - 04:50 PM
keep driving it and watch the damage build up could end up with a couple of hundred in parts if you distroy the lot
dave
#7 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 12 October 2015 - 05:16 PM
Wheel bearing.
To dangerous, get it sorted asap, at the very least establish what it is
#8 lee84
lee84
  • 79 posts
Posted 13 October 2015 - 12:43 PM
Wheel bearing.
booked into garage guys, will let you know the outcome
#9 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 13 October 2015 - 12:45 PM
If you plan to keep the mini for a long time then it's worth learning to do these simple jobs yourself as it will save you a fortune.
#10 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 13 October 2015 - 12:50 PM
Wheel bearing.
make sure they use timkin bearings
