My Clubby Aka Bumblebee
1 reply to this topic
#1 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 13 October 2015 - 03:17 PM
Well since my project has taken a turn for the worst I'm now rebuilding the engine for my mini which is an excuse to get the front subframe out and cleaned up and paint the whole engine bay. I've been working on it for a few hours most days doing bit's and pieces to get it just ready enough to be ready for the road and it did go in for it's mot but after failing on a few simple issues I've been trying to sort things I'm not happy with and I've just been adding to work pile.
Work carried out so far
New built backplates installed
Braided brake lines
Adjustable bottom arms and Tie bars
New wiring for headlights from WBW
Tidying up the wiring in engine bay
New clutch master cylinder, braided hose, slave cylinder
Wooden steering wheel
Custom wooden gearknob fitted onto KAD moke quickshift
Various other bits
Engine is now out and getting a full rebuild, well I'm building a 1330 up, depending on cash will determine when this gets done.
Pics
Because I've got halos for the sidelights, I linked the sidelight bulb in the indicator unit to the indicator circuit and paint the bulb orange.
11865360_10153601529522495_3567888778039
Trial fit of new dash
10854908_10153648909742495_4075582148816
Pics of engine in car
11942315_10153652140882495_8390437024368
11952883_10153652141397495_1348316481075
11999615_10153657776337495_7602378345668
Firewall painted in wrinkle paint
12002473_10153683540677495_5974193983644
12006648_10153694005672495_5946902225254
Trial fit of wooden gearknob on standard gearlever, now sits four inches higher woo
12045730_10153694005757495_7656006209137
Engine out
12132406_10153715368632495_5130346096977
Engine bay, notice that the previous owner has sprayed over the wires. Replacing the whole rear loom with an SPI
12087046_10153723595542495_8534709227037
#2 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 25 March 2016 - 02:57 PM
Anyone able to shed some light on the best flywheel kit I should be buying for my mini. It's an inertia type and I'd like a decent set up. Meds kit is about 300 but was wondering if theres something good for cheaper.
